make your own multimaster blades redux
jerseyjeff | Posted in Tools for Home Building on January 29, 2007 04:12am
After the Jersey Hash fest…
Cornedbeef hash that is
Shep pulled out his multimaster to show doncando…  which led me to thinking about finally replacing a small chunck of oak floor.  I did not want to use my 30 dollar ecut and find a cut nail,  so off to the despot I go…
The 8$ buck brothers miter saw has tiny teeth that almost seem bidirectional,
I tapped a hole using a step drill bit (unibit)
http://www.irwin.com/irwin/consumer/jhtml/detail.jhtml?prodId=IrwinProd100144
found 3/8″ to be almost  just right,   and then I used a dremel to section off the new blade from the saw.  I tried a nibbler but the steel was too hard.
I cranked the washer down hard,  and it worked quite well.   Found a nail on my second plunge!
I am going to use either the cutoff wheel in my grinder or roto zip on the next try…
but all in all,  a major success.
  1. mattias | Jan 29, 2007 05:33pm | #1
    The correct drill bit size would be 10 mm. 3/8" =9.52 mm. I have measured the Multimaster to 9,97 mm. A carbide drill bit in a drill press would do the trick even if the blade is hardened.
    1. Steddy | Jan 29, 2007 07:02pm | #2
      Absolutely - I've got the word out here to not throw away any snapped pull saw blades. My metal worker buddy has a step shear for the cross cuts and I punched the holes with the drill press. Made a variety of sizes, and have gone to these 'beaters' many, many times. I have a Japanese 'feather' file for touching up the good ones, too.
      1. woodman201 | Jan 29, 2007 10:12pm | #3
        Hi there why go through all that work when you simply spot weld new blades on the old mounts. I purchase a replacement HSS Japenese saw blade from Lee valley #60T57.02 and using a Zip disc on a hand grind cut them into sections from the blade that I need. I purchased the spot welder from EBay for $60.
        Bruce
        1. Steddy | Jan 30, 2007 05:12am | #4
          That sounds great, too. I haven't spent anything on blades or a welder (though I bet I could get my friend to whip something out), and I haven't worn through any blades to have their mounts available - the offset would be nice, though.
          I wonder what Fein would say if I asked for some empties to make my own blades with...
          Anyone know of a blade to cut up suitable for metal cutting?
  2. xMike | Feb 02, 2007 12:53am | #5
    I haven't had any luck locating a U.S. source for a 10mm drill bit.  Has anyone a source that they can recommend?
    Now that I have a new multimaster, I'm determined to make up a batch of multimaster blades.
    Mike D
      Sphere | Feb 02, 2007 01:16am | #6
      McMaster-Carr. They got any drill size you want.
      The secret to a long life is knowing when its time to go.  M. Shocked
      1. xMike | Feb 02, 2007 04:53am | #7
        Of course!  I should have thought of them.  That's where I got my cast-iron, machined pulleys when my new bandsaw wouldn't stay on the floor.
        Thanks,
        Mike D
      2. xMike | Feb 02, 2007 05:28am | #8
        Ordered!
        Thanks,
        Mike D
      IMERC | Feb 02, 2007 06:53am | #9
      http://www.wttool.comLife is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Episode 1: Drywall Tools for the First Coat
Learn about mechanical and automatic tools such as the taper, the compound tube, and the banjo to make your drywall job better and easier.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
