Hi,
I’ve just replaced a small section of oak strip flooring. Is there a way to give the new wood the older amber look of the old finish?
Thanks,
Mike
if you use a oil poly that will yellow it some.i have had some luck with shellac on trim ,it gives a yellow golden tint to the wood. don't know if it would work on floor. other than that play with some stain to get close. larry
With some scraps of the new flooring, experiment with various stains.
You'll not likely get a perfect match...but you should be able to get something close enough that it won't scream at you "Floor patch, floor patch!!"
J. D. Reynolds
Home Improvements
Go to Woodcraft or online and get some TransTint, I think the color is called Honey Amber. I add it to WB poly at about 8 drops per quart... it's exactly what you're looking for. Lemme know if you need any other info.
HTH
PaulB
