making unsquare appear square
semisavant | Posted in Construction Techniques on November 29, 2003 06:26am
I have an 8′ x 4′ room that is 2″ out of square (46″ to 48″). It has only a 3/4″ subfloor and no finished floor as of yet. This room is in the basement of an old cabin that I am attempting to renovate. It is adjacent to an 8′ x 16′ room on one side and a 3′ x 8′ room on the other side. The three sections are open to each other and at 3 different heights.
Any suggestions on how to put a finished wood floor on top of the unsquare sub floor? This room is open space between a utility room and a game / entertainment room. Will I be one of the few that will notice the 2″ ? It was suggested that I install a “mosiac floor” but it’d like to stick to wood.
Thanks in advance.
  1. FastEddie1 | Nov 29, 2003 08:27am | #1
    Two thoughts:
    Install 4 ft lengths of wood, so the strips go the short direction (no joints).  The difference in length won't be too noticable.
    If you have to run the wood the long way, use the widest boards possible at the walls.  If you taper a board from 5" to 3" it will be less noticeable than tapering from 2" to zero.  Even better, snap a chalk line down the imaginary middle, and taper each board 1", still using wide boards.
    Do it right, or do it twice.
      semisavant | Nov 29, 2003 09:37am | #3
      Great ideas! Thanks a lot.
      SteveTelling the truth means not having to remember. -- Twain
  2. HeavyDuty | Nov 29, 2003 08:50am | #2
    Or run the flooring diagonally, make sure you like the look though.
      semisavant | Nov 29, 2003 09:39am | #4
      I like diagonal. It would certainly add to the already interesting layout.
      Thanks for your time...
