manuf. for slow rise foam insulation
I have an insulation application that consists of a CMU residence that has its interior wall finishes as follows. nominal 1×2 furring with 1/2″ drywall plus plaster. leaving a nominal 3/4″ void between the CMU exterior wall and the interior finish.
It is this 3/4″ space that I wish to insulate. I have concluded that foam is the better choice vs. cellulose, which will not fill the void reliably. To date, I have found only one manufacturer, FOMO, of a slow-rise 2 part foam that will do the job. The slow-rise formula allows the foam to rise up the cavity sufficiently before curing, as well as not stressing the mechanical fastening that hold the drywall in place. This is a renovation condition where interior finish penetrations must be kept to a mnimum
Are there any other sources of a SIMILAR slow-rise product that anyone has had experience with?
Greetings Chris,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someones attention that can help you with advice.
Cheers
'Nemo me impune lacesset'
Let's try this one more time.
If you fail to get the info desired you might want to try the JLC forum.
http://www.jlconline.com/cgi-bin/jlconline.storefront
Cheers
Edited 1/21/2006 4:06 pm ET by razzman
