I’ve started using a manufactured stone installer that seems to be doing very good installation work. We tyvek our houses, then flashwrap our windows with window flashing. He then installs felt paper over our tyvek and runs it and the scratch coat of mortar right over the flashed flange of the window.
My question is this: Should we also caulk the edge between the window and the stone? Its obviously not a uniform gap, since each stone has different profiles.
If we should caulk, what do you recommend? We would want it to be as non visible as possible.
If we don’t caulk, are there any other methods we could use to minimze the potential for water infiltration, or are we doing it already?
Thanks!
I presume he's installing metal lath over the tarpaper for his scratch coat....or at least some metal bonding clips.
Vulkem 921 is a good caulking for your application.
You might want to look at this article.
http://www.jlconline.com/cgi-bin/jlconline.storefront/42a344e4000f236827177f000001059f/Product/View/0412manu
If you don't have that issue of JLC you can buy the article online.
