Materials Used Based Off Photos
icu222much | Posted in General Discussion on January 1, 2021 10:41pm
I am wondering if someone can determine the materials used in this home based off the photos? Note that the home is built in Richmond, BC, Canada (near Vancouver) in 1990s.
Photo: https://imgur.com/a/tBSRDvg
Plumbing Materials (Is it copper? I thought that was used only for very old homes)
– Copper
– Copper and PVC
– Poly-B
– Galvanized
Electric Materials
– Copper with Circuit Breaker
– Aluminum with Circuit Breaker
– Aluminum with Fused
Electric AMPS
– 100 AMPS
– 100 AMPS with 200 AMPS
– 200 AMPS
Roofing Material (I think it is asphalt shingles)
– Asphalt Shingles
– Solar Tiles
– Stone-coated Steel
– Slate
– Rubber Slate
– Clay & Concrete Tiles
– Green Roof
– Tar & Gravel Roofing
  1. mikemahan3 | Jan 02, 2021 10:47am | #1
    The water pipes are copper. There looks like there is a short piece of plastic and galvanized in there. This was probably done well after the house was built. The plastic could be PEX or CPVC. If there is galvanized in the water line it should be replaced. If there is gas pipping in the states it would have been black iron for inside, galvanized where exposed and coated iron underground. I can't say about Canada.
    The electric is most likely copper for any circuits of 30 amps or less, but possibly aluminum for larger circuits or feeders. Judging by the size of the panel I'd guess 200 amps. The main breaker at the bottom should be marked.
    The roofing looks to me like wood shingles.
