Max superframer
porkchop | Posted in Tools for Home Building on February 11, 2005 08:39am
My trusty max superframer (sn890rh) has a broken driver, and the tool repair place wants $170 plus labor to fix.  Has anyone else had this problem?  I think I’ll just get a new one unless anyone has some spare parts they’d like to part with.
  1. rez | Feb 13, 2005 12:37am | #1
    bump
    "Live Free,
          not Die"
  2. trimmer | Feb 13, 2005 02:01am | #2
    Are you not capable of replacing the part? See if this page will open for you, http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/maxtools/SN890RH I think the part you are needing is $98.00
    1. porkchop | Feb 13, 2005 09:39pm | #5
      I think replacing the part would be pretty easy...  However, with the one for sale on ebay, I might just buy that and keep the broken one for parts.  The driver actually cracked in the middle, so the only way to repair would be to weld it, and I'm not sure that would work well on the hardened steel of the driver.
    skyecore | Feb 13, 2005 01:13pm | #3
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=50378&item=4356104774&rd=1&ssPageName=WDVW
    I hope that link worked..
    if youre comfortable with Ebay, this looks like it might go for just a bit over what that part will cost..
    if the link diddnt work, search "max framer" on ebay
    ______________________________________________
    --> measure once / scribble several lines / spend some time figuring out wich scribble / cut the wrong line / get mad
  4. junkhound | Feb 13, 2005 02:51pm | #4
    What is broken?  One of my nailers that failed was simply the thread into the piston - a 50 cent helicoil and red locktite made it better than new.
  5. cawfy | Feb 14, 2005 06:05am | #6
    Same thing just happened to my pc finish gun.Luckily it'll only cost 40 - 55 bucks + shipping.Anyone have the same experience w/this gun?If so how often? I'm thinking of getting a different one.
    Thanks,and good luck Ian
    I'm using a poter cable da250a
    Edited 2/13/2005 10:33 pm ET by cawfy
