Hi Everyone
I am putting in a bathtub and I need some help, Because you can’t see what you are doing on the underside of the tub how do you measure with extream accuracy to make sure that the drain pipe lines up with the tub. This may be a silly question.
Is there an easy way to do this and do you fix the tub in position before you start any plumbing.
Thanks for your help everyone
Peter
Are you open to ta basement or crawl space?
I have hooked up the drain to the tub adn teh tub overfowl and then set teh tub. And then from below or throug a side access hole plumbed in the PVC piping.
