Meausuring drawers for use with European Slide hardware
prout35 | Posted in General Discussion on February 16, 2011 04:57am
I am about to build drawers for on existing kitchen cabinet. How do I go about measuring so the new drawers will fit the cabinet after I install the hardware?
Are there illustrations or video of this process on line?
  1. [email protected] | Feb 16, 2011 05:24pm | #1
    It is dependant on the hardware.
    You need to decide which hardware you are using, and the instructions will tell you what clearances you need to build in.
  2. JMadson | Feb 20, 2011 10:58pm | #2
    need more info
    What slides do you want to use?
    Face frame or framless cabinets?
    Most slides that go on the sides nowadays are 1/2" each. So your drawer can be no larger than the opening minus 1". Most also have a way to account for some play but only in one direction. You can make the drawer 1-1/16" to 1-3/32" smaller than the opening and if you put the screws in the right holes, you'll be fine.
Fast, Accurate Wall Framing
  • Smarter Stop Block
