Hello there,
Does anyone have some suggestions for attaching moldings (1/2″ x 3 1/2″ MDF) for window and door frames? The work is to be perform in a newer tall apartment building where I am sure most construction is of metal stud.
Thanks,
Vancouver, Canada
Some suggestions: countersunk self-drilling screws, construction adhesive and temporary bracing, drywall anchors with countersunk screws, p.i.t.a., bid accordingly
CaliforniaRemodelingContractor.com
Depending on the gauge of the steel, a 15 ga finish nailer and spot gluing will work well.
Doors-if metal jamb, no wood liner. If wood jambs-possibly metal frame is lined with wood.
Finish screws-self tappers.
http://www.quittintime.com/
When trimming a space framed with metal stud, I like to pre-assemble window and door frames and install in one piece. I use nails where applicable and trim head screws with construction adhesive where nails won't do.
J. D. Reynolds
Home Improvements
Use the advanced search for "trim metal studs". There's been several threads on this the last few months.
Here's one of them 94361.14 buic
