I’m remodeling an interior space and plan to use metal studs instead of wood. The logistics of this project makes steel studs preferable.. I think. I’m using regular wood *ignore* doors not, wrap-around metal jambs and also have to hang a fair amount of upper cabinets. Needless to say, I’m concerned about the strength of the studs. Previously I’ve screwed solid wood backing (2×4’s) where cabinets had to be & I guess I’ll do the same at the jambs. Is there any other suggestions?
I'm remodeling an interior space and plan to use metal studs instead of wood. The logistics of this project makes steel studs preferable.. I think. I'm using regular wood *ignore* doors not, wrap-around metal jambs and also have to hang a fair amount of upper cabinets. Needless to say, I'm concerned about the strength of the studs. Previously I've screwed solid wood backing (2x4's) where cabinets had to be & I guess I'll do the same at the jambs. Is there any other suggestions?
