metal stud framming door instal
ManuelLabor79 | Posted in Construction Techniques on November 25, 2008 08:07am
whats the best way to hang an interior door to metal stud framming, fasten it?
    Sphere | Nov 25, 2008 08:11pm | #1
    Infill the stud with wood, and nail as usual.
  2. calvin | Nov 25, 2008 08:48pm | #2
    worst case scenario if the opening is already made up with the metal studs and you can't add the 2x4 inframe w/o screwing up the opening.
    Screw blocks of the proper thickness to the studs (inside the opening) in places you want to fasten the jamb.  Use a nail gun to fasten to the blocks.
    Bring the opening in to just short of that needed for jamb, plumb the blocks while installing.
    http://www.quittintime.com/
    1. VMackey | Nov 26, 2008 01:42am | #7
      On walls that are framed all steel and already drywalled, and for some reason no one in charge wants to do it right and let you cut / patch the drywall to install blocks, I've found than a nice sharp blow from a framing hammer will knock the offending steel back into the wall and out of the way so a nice stick of 2x can be fit in and screwed down tight.
      If you can find the original screws in the steel stud / track you don't have to swing that framing hammer as hard. But swing hard enough and hidden screws aren't a problem. I'm found letting the secretary who's desk is closest to said doorway ahead of time helps make the rest of the day go smoother. Vic
      1. calvin | Nov 26, 2008 01:57am | #8
        I see, done punch work on commercial have we?
        1. AitchKay | Nov 26, 2008 03:06am | #9
          Right. Why do you think they call it punch work!AitchKay
          1. calvin | Nov 26, 2008 03:41am | #10
            When we had the finish contracts on commercial projects we often pushed for the blocking contract as well (when they were offered separate and not part of the framing package) so we wouldn't have that there punch out list.
            We got in on the finishes with one GC (huge firm) and they knew our eagerness to work period.  If we got one bid-almost guarantee we'd get the other, on reputation alone.  Nothing worse than tearing walls open when you can't find the blocks for those bath partitions.A Great Place for Information, Comraderie, and a Sucker Punch.
          2. AitchKay | Nov 26, 2008 05:46am | #11
            You got that right!I know some contractors would completely sheath a commercial bathroom with 3/4" ply to avoid problems with missing blocking. And then, years later, when the toilet-stall partitions got relocated, possibly for ADA reasons, that original contractor would end up looking like a million bucks!The lesson is, know as much as possible about the trades that will follow, and then go the extra mile. As in your experience, smart contractors will figure out when they've got a sub who will make sure that future problems don't come up. In the long run, you'll be rewarded for that.Aitchkay
          3. calvin | Nov 26, 2008 06:05am | #12
            It certainly didn't hurt that they had been screwed in the past, sometimes even when done in house.
            Oddly, we never abused the open door in the bidding process.
            So much said for good business practices.A Great Place for Information, Comraderie, and a Sucker Punch.
  3. FastEddie | Nov 25, 2008 09:26pm | #3
    Ditto sphere.  You might have to use treated wood depending on code, and you will have to either chamfer two of the corners or rip 1/8" off the width to get the wood stud to fit inside the curled flanged of the metal stud.
    1. calvin | Nov 25, 2008 11:39pm | #4
      Usually ed, we'll orient the studs at the door opening flat side in.  Screw through the channel side into the wood member.A Great Place for Information, Comraderie, and a Sucker Punch.
      1. FastEddie | Nov 26, 2008 12:00am | #5
        Ok, but if you are going to place the wood stud into the cavity of the metal stud, it needs to be trimmed to fit."Put your creed in your deed."   Emerson
          CapnMac | Nov 26, 2008 12:09am | #6
          A person can reverse the framing points out and remove the stud so the PTD 2x can be slipped inside.  That person has to have a good hand reinstalling the points as they will strip out in an eyeblink, though.Occupational hazard of my occupation not being around (sorry Bubba)
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
