The designer has specified attaching a deck beam to the exterior of the house using a beam pocket. The beam will sit on top of the poured concrete foundation so the pocket is cut into the bottom 3 courses of brick. We’ve looked at alternatives such as a hangar or a new sono tube pier but it would have to be footing depth (7′) so this is our best solution. The beam will supports a full roof and screened in area above. My question is what is the best way to seal around the 4X2X10″ PT beam in the brick wall.
Mortar.
don't waste words will you!!
I have to be brief. If you see the volume of posts I've made over the years, you'd know why. I'm trying to close down on Piffin. Bob's next test date: 12/10/07
I'm not even going to try to catch him.
I understand that you need to leave space on either side of a beam in a 'pocket' that's in a masonry wall, n'est ce pas?
Let's not confuse the issue with facts!
Is this brick veneeer or a structural brick wall?
New construction or adding to existing?
Does the designer really know what they are doing?
