Every time I search for staircase handrail or hand rail I get directed to:
which is about plumbing.
I do get to messages about Staircases when I search for staircase though.
Have you tried the advanced search?
http://forums.taunton.com/n/find/find.asp?webtag=tp-breaktime
Search feature on this site is kind of hormonal and not always willing to help you, but the advanced does some better.
Other options are try again tomorrow, or ask your stair rail question in a new thread
I am in the midst of replacing all of the old galvanized water supply pipes in my home with new copper supply pipes. As far as sizing the pipe diameters, is it best to run 3/4" up to the second floor and then 1/2" to each second floor fixture? For instance, I am worried about having adequate water pressure upstairs when the basement washing machine kicks on. Thanks for the help.
-Steve
Man, you got the A-1 original search question redirecting post.
Steve has become near famous for this reason.
Best of luck in your search........advanced might work mo-better.
http://www.quittintime.com/
Has Rez ever given Steve his just reward?http://www.tvwsolar.com
We'll have a kid
Or maybe we'll rent one
He's got to be straight
We don't want a bent one
He'll drink his baby brew
From a big brass cup
Someday he may be president
If things loosen up
You know, he really should come up with something. That there plumbing post will live in infamy..............
until they fix the search function.
Which is why it'll be there forever!
Has anyone tried a search for his copper pipe question? Might get the answer to the universe as a result. God knows you won't get the original.A Great Place for Information, Comraderie, and a Sucker Punch.
That glitch has been there forever. I don't believe that it can't be fixed, but can't figure out the rationale for not fixing it. If there was a magazine called Fine IT Department, this would be on the last page.
Forty-two
Dinosaur
Can't be, it isn't a prime #
Dinosaur
When I click on your link the plumbing thresd shows for about two seconds and then this thread about handrails shows up;
http://forums.taunton.com/tp-breaktime/messages?msg=13436.1
On the left are more handrail threads.
Mike
Small wheel turn by the fire and rod, big wheel turn by the grace of god.
Do a search about plumbing.
Yeah, when I click on your link I get the handrail thread http://forums.taunton.com/tp-breaktime/messages?msg=13436.20 .
Clearly, FHB is out to get you.
