I’m building a home in W Va. Last fall in order to protect the subfloor over the winter I covered it with an EPDM membrane. Every thing went well over the winter. No leaks. We began working again in April of this year. I left the EPDM on while we were working for protection from the elements, as I can only work on the weekends. Understandably as we started nailing plates, walls, braces some water worked its way through the subfloor. What am I facing here in terms of replacing plywood, mold etc.?
thanks, jack
Edited 5/10/2004 3:31 pm ET by wvjack
Can you pull up the EPDM and take some pictures to post here? It's impossible to know from what you wrote whether this is no problem or total disaster.
-- J.S.
Is the EPDM still in place?
Yes, it is still in place. I really don'twant to take it up until the house is dried in which will be in a couple of weeks-working only on the weekends doesn't leave a lot of time. What I'm looking for is the potential disaster-or not- that I'm facing.
jack
Moisture under EPDM wasn't there until you started nailing thru subfloor???
I'd look at the other side of the problem: water vapor coming up thru the subfloor and condensing on the underside of the EPDM. It's a nice tarp, but it's also a great vapor barrier. If you have a damp basement (and who doesn't?) and an unheated house during the winter, you have condensation wherever the temp crosses the dewpoint. The basement floor is (generally) below the frost line; therefore the basement stays warmer than the air upstairs. I think.
Of course, this is all speculation on my part. Don't quote me yet. I'm still learning.
