Years of moisture in the basment of my g/f’s home has left mold on the bottom 12″-16″ of drywall and the frameing. The drywall fix was simple, rip it out and take it to the dump.
Now I am wondering what to do about the bottom plate and studs that show mold, being that they are non bearing walls I can cut the most of it out and replace it or treat the mould.
The moisture problem has been fixed now I need to know how to deal with this black mold!
Edited 2/3/2006 9:01 pm ET by bake
A thorough soaking in bleach should help get rid of it.
If you go the bleach route, make sure you get the mixture of bleach to water correct. I don't know what it is off-hand, but I do know for a fact that a milder bleach/water mixture is far more effective than straight bleach.
FWIW, the bleach/water solution would be my first plan of attack.
Mold, not mould!
It will cease living with out the proper moisture tempature ratio.
DO NOT PANIC!!!!!!!!!!!!!!!!!!!!!!!!
[email protected]
I second Eric's comments. I'd also recommend a look at http://www.buildingscience.com.Andy
"Never try to teach a pig to sing. It wastes your time and annoys the pig." Robert A. Heinlein
"Get off your dead #### and on your dying feet." Mom
I'm no expert by any means, but there is a lot of information out there to the effect that bleach is ineffective as a black-mold killer. I would definitely do some research on the net before deciding on a treatment. There are commercially produced mold-killers available. Again, I'm not an expert, but I do know the health ramifications can be serious, and it shouldn't be taken lightly.
"he...never charged nothing for his preaching, and it was worth it, too" - Mark Twain
Kill with bleach, then seal with kilz, carry on with life.
The difference between stupidity and genius is that genius has its limits. -Albert Einstein
http://www.peteforgovernor.com
We use Timbor. Kill it with a bleach solution. Soak the wood framing with a Timbor solution (up to about 3'). Let it dry a week then rock it with paperless drywall. DONE
http://store.doyourownpestcontrol.com/cgi-bin/pestcontrol.storefront/43e49700019be780273f4200c1480644/Product/View/I421#fungi
Edited 2/4/2006 8:59 am ET by scottthebuilder
