Hello,
Can someone describe how they have (or would) switch a remote fan pulling from two bathrooms. I would like to do timers in both bathrooms – but can’t think how you would do it with effectively a three-way circuit…?
Hello,
Efficiency, solar power, and a sensitive kitchen for an 1830s house in New York.
No three way
Run power to the fan, drop two separate switch legs to the timers.
No special timers, the push button is my choice. Single pole.
I'm just a dumb carpenter, my electrical sub did the hookup. I'm sure one will drop by than can explain what goes where up at the fan.
Timers
The Leviton 5-10-15-30 minute timers I like to use are three-way switches, so you can use two of them for one fan.
You don't need a 3-way switch, you just need the two timers wired "in parallel", so that either one will make the circuit. Two wires to each timer, just like for a single timer, only at some point you wire them together, matching colors.
