multimeter reading interpretation
k1c | Posted in General Discussion on August 8, 2010 02:23am
Hi.  I just tested the ice maker solenoids.  The meter is Ideal autoranging digital.  One solenoid that has 35v stamped on top (and supplies water to icemaker and assumed defective) reads 193.0 ohm.  Other solenoid has 15v stamped on top and reads .394k ohm.  Would you explain what these numbers mean, although I may have to know their normal resistance, which I don’t have as yet.
Also why is one a whole number and the other in decimals with k after it?  K means 1000, right?  So why is the number in decimals?  Sorry but that is all the background information I have now.
The meter range/resolution for resistance is 400.0/4.000k/40.00k/400.0k ohm.
The solenoid assembly was completely disconnected from water lines and power supply.
Thank you in advance.
  1. k1c | Aug 08, 2010 05:37pm | #1
    multimeter
    Thank you for the reply.  That makes it clear.  Now I know the likely problem is the ice maker module.  Again, thanks.
    1. DanH | Aug 08, 2010 05:51pm | #2
      Do spend a little time checking for a broken wire or loose connection.  Especially any wires that are subject to movement or vibration.
      1. k1c | Aug 08, 2010 11:14pm | #3
        Sorry but this just popped into my head.  Can the resistance reading of 193 ohm mean that the solenoid wire is loosing resistance and at the end of its life?  Just a speculation based on comparing two solenoid ohm numbers.  Again thank you for your help.
        1. DanH | Aug 09, 2010 07:29am | #4
          No, as the wire nears the end of its life (which is generally very long) the resistance will go up.  The coils have different resistance because of their power needs.  The more powerful the coil needs to be, the lower its resistance for a given voltage (or the higher the voltage for a given resistance).  Power is voltage squared times resistance.
          1. k1c | Aug 09, 2010 02:07pm | #5
            solenoids
            Thank you very much for all the help.  I will give the valve one more test to make sure it's not stuck closed.  Can't do any more tests.  I've run out of time according to my kids.  Again thank you.
          2. gfretwell | Aug 09, 2010 04:00pm | #6
            Are you sure the ice maker is cycling?
            Try it by pouring some water in the tray from a container and see if it dumps ice.
          3. k1c | Aug 12, 2010 12:43am | #7
            ice maker
            Thank you for reply.  Exactly that was the second thing I tried per repairclinic suggestions.  The problem was in the icemaker.  Instead of trying to test the parts in the icemaker, I just ordered a replacement icemaker.  Again thank you.
  2. catmandeux | Sep 07, 2018 04:06pm | #8
    https://www.fluke.com/en-us/l
    https://www.fluke.com/,,,,,,,,/what-is-true-rms
  3. calvin | Jan 31, 2019 08:05am | #9
    More spam, someone from FHB going to see this and delete as part of the “NEW” more user friendly, updated, spam blocking, easy to use if you like to scroll .......
    Forum?
