Like most people, the part of painting I hate most is the prep work. Especially puttying nail holes. Anybody have a favorite filler that is easy to apply, easy to sand and (ideally) doesn’t shrink?
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
Quebic Iridium is awesome.....
" Iam not a poet, but your hat is singularily inadequate"
I googled on that and didn't find any hits. Can you provide some more info?
I think (hope?) Sphere is yanking your chain. I've used vinyl spackle in the past and liked it, but I generally just use drywall joint compound now because I usually have a tub of it sitting around.
I thought my chain was being yanked, but you never know. Who would have thought something called Gorilla Glue would be a real thing? Thanks for all the real replies.
I'm just surprised PETA hasn't raised h*ll with them for making glue out of gorillas...
PaulB
(Loved the line in the Addam's Family Movie where the daughter asked the Girl Scouts - "are they made from real girl scouts?")
excuse Sphere, he has inhaled a little to much Quebic Iridium.
If you are talking about painting woodwork, there really is no easy way, unless you don't mind the nail holes showing. I usually use a lightweight spackle. it's a matter of learning to apply the least amount needed to make it easier
I've been using wood filler, if I can see it, I can smooth it.
Before its painted.
Gord
I use the "One Time" spackle if painting. It will halo if you are not careful. I like the Elmer's Wood filler, wet "sand" it with a sponge or rag. If staining I found the basic same product in tubes in various colors that seems to work well. I used the "natural" they have oak and at least one other.
Try Bondo. Mix it with hardener and it's dry in 20 minutes. And it doesn't shrink. I've even fixed broken moulding with it.
Headstong, I'll take on anyone!
I use Elmers wood putty for nail holes and Quebic Iridium for Piffin screw holes...
If Blodgett says, Tipi tipi tipi it must be so!
TipiFest 06~~> Send me your email addy for a Paypal invoice to the greatest show on earth~~>[email protected]
That Quebic Iridium is highly reactive and spontaneously combusts in the presence of methane. The stuff also emits a faint green light in a darkened room. So I don't recommend it in a bathroom even though it makes a nice night light.
This is why i said I just use it with Piffin Screws...its the proper application in this case....geezzzzIf Blodgett says, Tipi tipi tipi it must be so!
YES to the Elmer's wood putty. The stuff is the best and easiest to work with! I love it.
The difference between stupidity and genius is that genius has its limits. -Albert Einstein
http://www.peteforgovernor.com
Depending on the finish level you're going for.... fill and sand is nice, but an adequate job (no complaints from my customers, anyway) can be done using putty, painters or glazing (33) mixed with enough plaster (dry powder) to make the putty stiff enough to shear flush with the hole with a push n' rub with the thumb.... a quick wipe (buff) with a clean rag will clear the halo.
Fill after prime, then topcoat after fill.
Stained finishes can be filled with color puttys similarly..... fill after first coat of poly then apply final coat Color putty's can be mixed to get the look of the stain, or you can add stain pigment to the putty to match extremely close to color.
If you're going for cabinet grade finish, then yeah... fill and sand.
Crawfords... rocks!
putty for smaller holes
their spackle for larger...
http://www.crawfords.com/
