Nailing clapboards
KaneoheBay | Posted in General Discussion on April 27, 2009 09:31am
I’ve read articles and seen TV shows where several techniques of nailing clapboards were shown (of course not at the same time); i.e., at the bottom of the clapboard through both courses, through the bottom of the upper course only (and no nails at the upper edge), and finally through the upper course (upper edge) under the covering course (with no nails at the lower edge).
What’s the consensus?
Thanks in advance.
  1. Piffin | Apr 27, 2009 10:32pm | #1
    "consensus?"
    you do realize where you are, don't you?
    1. KaneoheBay | Apr 28, 2009 03:21am | #7
      Heh! Heh! Heh!
      I guess I'll try my best to sort it out.
  2. YesMaam27577 | Apr 27, 2009 11:17pm | #2
    I live close enough to the coast (almost a two hour drive) that the building code requires both the blind nails and the face nails (top edge, and bottom edge) -- assuming true clapboards.
    In addition, manufactured siding products like hardie require both rows of nails, at least in high-wind areas. Dunno about your area -- your mileage could vary.
    Politics is the antithesis of problem solving.
    Mongo | Apr 27, 2009 11:25pm | #3
    I don't blind nail.
    I don't have a single nail go through two claps.
    For 6" claps (5-1/2" nominal) with 4-1/2" exposure, I'll nail bout 1-1/4" up from the butt end.
    I use stainless steel ring shank nails, I nail through the sheathing and into the studs.
    No one will refute my methods, for I am the master.
    1. notagain | Apr 28, 2009 02:58am | #6
      What would you do if there were no studs.............ie, structural insulated panels? Rod
        Mongo | Apr 28, 2009 03:55am | #9
        I put a rainscreen with vertical furring strips 16" oc.Then nail off through the furring strips and into the osb skin.
    Ted W. | Apr 27, 2009 11:48pm | #4
    The Consensus?
    THE CONSENSUS???
    You can't handle the consensus!!!!
    haa haaa... drama
    ~ Ted W ~
    Cheap Tools! - MyToolbox.net
    Meet me at House & Builder!
    Edited 4/27/2009 4:49 pm by Ted W.
  5. MikeSmith | Apr 28, 2009 12:49am | #5
    if you have two nails thru one clap, you will get a lot of splits down the road
    traditionally, claps are nailed just above the overlap, so a traditional 4" exposure with a 5 1/4 clap will get nailed 1 1/2 " above the butt
    most of the time i see them incorrectly nailed about 1/2 " above the butt, which puts 2 nails thru every clap
  6. edwardh1 | Apr 28, 2009 03:30am | #8
    Buried in the hardie specs if i remember is the wind rating- I think its 125 MPH for blind nailing ( 1 hidden nail) and only 150 MPH for the face nailing (i blind and 1 face) for their lap siding. i did blind nailing even tho I am in a coastal area as I think face nailing looks bad and 150+ mph would probably blow the house away.
    1. YesMaam27577 | Apr 28, 2009 06:03pm | #12
      >>"i did blind nailing even tho I am in a coastal area as I think face nailing looks bad ......"Are you confident that your insurance will cover you if your hardie blows away, and your house does not? If it was not installed in accordance with the manufacturer's specs, some might not.
      1. edwardh1 | Apr 28, 2009 06:55pm | #13
        are you kidding, with all the other construction errors that exist in the world. when face nailing becomes a law then do it
        1. YesMaam27577 | Apr 28, 2009 10:26pm | #14
          >>"when face nailing becomes a law then do it"Well, in most states, the builing code is written into law.And just about every version of every building code says that manufacturer's specs and instructions are key.And so, when the hardie specs say that face and blind nails are needed in high wind areas (like coastal areas), then face nailing is the law.One possible exception...... It is possible that your local building code authorities have declared that your particular coastal area might not be defined as "high wind". Or that they have failed to declare the area as "high wind". In either of these cases, you're probably legal.I live about two hours from the NC coast, and in my county, we are required to follow 'high wind' specs. An if we don't, we need to worry about our insurance coverage.
          1. MikeSmith | Apr 28, 2009 11:45pm | #15
            i think  you're  fulla shid
            gimme  some  chapter  and  verse  about  face nailing  siding  in   the  code
             i  work in  110  mph  zoneMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
          2. YesMaam27577 | Apr 29, 2009 03:22pm | #17
            It's probably not in the code -- its in the installation instructions for hardie siding products. And since its in the instructions.........
          3. MikeSmith | Apr 29, 2009 08:38pm | #18
            Hardie is really starting to pizz me off.. they have so many things in their instructions that are contrary to good practiseMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
          4. levelone | Apr 30, 2009 07:02am | #19
            I understand some don't like the finished appearance and there are installation quirks, but what is contrary to good practice?
          5. MikeSmith | Apr 30, 2009 01:11pm | #20
            i'll give you 2 :
            bottoms of claps 2"  above horusontal /roofing surfaces
            and not caulking their butt jointsMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
          6. edwardh1 | Apr 30, 2009 03:07pm | #21
            Agree on the 2 inches- seems excessive to me - 1 inch should be fine
          7. levelone | May 01, 2009 03:18am | #22
            I may be mistaken, but I think Hardie used to say 1", but now recommends either 1" or 2" depending on geographical location.  The only thing that makes sense to me (and I've never heard of it) is that there might be an issue of delamination on non-factory edges during freeze/thaw cycles and a 2" gap may help--even though it is incredibly ugly.
            I have wondered about the tapered cuts on the rake, especially if cut with shears.  If care is not taken during the cut it can get a bit ragged and fuzzy.  In snow country would it be possible for water to wick into the planks and cause delamination?  So now they ask for 2" gap and primed ends.  I do wonder why.
            As for the no caulk at factory butt joints, I think it works great.  I've had more problems with guys leaving too small a gap and not being able to get enough caulk into it.  The caulk shrinks and then there is a gap.
            Tar paper joint backers, butt ends tight, a good paint job covers over the joint.
          8. MikeSmith | May 01, 2009 04:48am | #23
            it's supposed to look like clapboards......
            if they're worried about delamination, then they have more problems than we can imagine...it's not about delamination...it's about some stupid  installation instructions
            all joints have to be caulked to look right with a paint job
            so if the problem is an incorrect caulk gap...fix that...don't tell me to not caulk it
            and.... FC is supposed to superior to cedar in weathering properties, we keep ALL siding 3/4 off horizontal surfaces and roofing
            so the 2" is beyond dumbMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
  7. oldhand | Apr 28, 2009 03:56am | #10
    Mongo about summed it up assuming it is wood. Blind and face nailing or nailing through both overlapping pieces will result in an eventual split fest in my climate.
    1. edwardh1 | Apr 28, 2009 03:20pm | #11
      true on wood , dont think the hardie does that though.
      1. oldhand | Apr 29, 2009 02:27pm | #16
        For sure wood and fiber cement have different habits. For fibercement I always look to the manufacturers recommendations, it will vary some between brands..
Tall Deck on a Sloped Lot
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
  • Sharp-Blade Solution
