need help finding Square lattice
| Posted in General Discussion on January 4, 2002 04:59am
Does anybody have a source for square holed lattice. Not the kind that goes on an angle and not vinyl or plastic. I,m located in the Catskills about an hour from Albany NY. Thanks
  1. Mike_Smith | Jan 02, 2002 03:02am | #1
    it's out there.. try a special order at your local lumber yard..available in cedar, pine, and PT...
    however.. some of the green lattice is available in a traditional green.. very heavy..... goes well with victorian ..
    no maintenance...doesn't fall apart
    1. FredB | Jan 02, 2002 08:51am | #2
      *Hey if you are particular about lattice pattern why not make it yourself? A couple hours with some slats and a stapler and you'r in business.
      1. iron_helix | Jan 03, 2002 02:07am | #3
        *BrianTry http://www.britewaymanufacturer.com for polymer composit diamond and square pattern 4'x8' lattice panels. The company is based in ontario canada and from our local wholesales the cost is about $30 per sheet.retail 39.95 is about right. I hope the address is correct................it from what's left of an old memory..................Iron Helix
        1. Jay_Zog | Jan 03, 2002 04:07am | #4
          *http://www.all-coast.com/ lattice woodworks of oregon lwo/ woodway
          1. iron_helix | Jan 04, 2002 04:55am | #5
            *Brian,Address revision from found files..........www.britemanufacturing.com................Iron Helx
  2. Brian_Mulder | Jan 04, 2002 04:59am | #6
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
  • Townhouse Transformation
  • Mortar for Old Masonry
  • Grout-Free Shower Panels
