We have a transition area about 4X5′ between a beveled oak floor going one direction and a wide plank pine floor going the opposite direction. We are looking to lay 3/4″ stone in mortar in this area to match our fireplace, which is an Ohio/Michigan type river rock. The manufactured facing rock is too rounded and too thick for a floor surface. Resources on manufactured flooring stone of this type or suggestions on splitting natural stone would be greatly appreciated. If all else fails, we would consider having a slab cut to fit the area, but would prefer the rock look. Thanks!
M Ogle
Greetings imhome,
As a first time poster Welcomre to Breaktime.
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someones attention that can help you with advice.
Cheers
Rather than trying to match the fireplace, why not go with a contrasting material? Maybe use slate or granite tiles. They are readily available from tile supply houses, and easy to install.
Thanks for the reply. I would consider using a single slab of stone. How would I go about locating such material? What would I call it?
Look in the phone book under marble or stone and start calling stone dealers. They will put you in touch with a fabricator.
How about a piece of solid surface (Corian)? Renewable, one-piece look and affordable.
Joe
