Need store or website to buy plugs for foundation vents. I’ve seen mention of both foam rubber and styrofoam plugs but can’t find a local dealer. (the dirt floor of the foundation is covered with plastic.)
Thanks.
Thanks.
Uhhhh....Maybe just rigid foam cut to push fit? Or cut small and foamed in place.
Make sure you have really stopped vapor penetration though. Poly on the floor, while a good start, might not cut it. What about the walls? they are going to be dumping mass water from the ground contact.
MERC.
