In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
New Door Sill, Draft free design?
cwf | Posted in Construction Techniques on August 30, 2004 02:22am
Does anyone have a good detail for a new door sill that doesn’t convect cold air? (not the sill of the door assembly, the area directly below that the sill rests on)
I have a 150 yr old home – timberframe on stone-rubble foundation just outside of Toronto.  While the existing front door isn’t that old (30yrs), there has always been a considerable draft in the winter months.  The existing condition is a 2″x8″ wood sill resting on the rubble foundation wall.  I have tried spray foam underneath etc…to no avail.  Also, I have wrapped the foundation exterior with 2″ foam.
Now I am replacing with a new steel entrance door (gotta Love clearance sales!).  But I don’t want to put the new door on the existing sill, I’d rather solve the problem! Be it pour a new cement curb below (isolate with s-foam), or whatever ideas you have…
Does anyone have a good detail/technique for building a sill that is draft free?
Thanks for any suggestions!
Charles.
Edited 8/29/2004 7:24 pm ET by chas
    Dinosaur | Aug 30, 2004 05:10am | #1
    Pull the old sill and verify the solidity/integrity of the foundation wall. Get that as air tight as you can: parging, urethane foam, whatever works for your situation. Many drafts in this type of structure are coming in through the foundation wall and thence up through the floor.
    For the sill: Build a small form and pour a concrete cap on the area of your foundation wall where the sill will sit.  Before you pour, paint the top of the foundation wall inside the form with a concrete bonding agent such as Gel-Crete. This will avoid a cold joint.
    If height allows, make the cap at least a couple of inches thick. If not, use some Fibreglas matting to reinforce the concrete and make it as thick as you can. Insert two or three J-bolts into the wet concrete. Once the concrete is dry and cured, push two strips of sill-seal on over the j-bolts, drill a new 2x8 sub-sill to match the bolts, and torque it down to compress the sill seal about 30-40%. You should see no gaps between the wood and the foam.
    Obviously, you're going to have to counterbore so the washers and nuts are not proud of the top of the sub-sill. Make sure the threading on the J-bolts goes down far enough that you'll be able to get the nut below the surface of the 2x8; you may have to run a die down close to the bend considering that j-bolts are meant for foundation pours where the bolt can be inserted to any depth needed. Or just get some 3/8" threaded rod and bend it into an L using an oxy-acetylene torch.
    Dinosaur
    1. cwf | Sep 02, 2004 03:36am | #2
      Hi Dinosaur, Thanks much for your advice...these are some great ideas.  Conceptually I was thinking the same, but didn't know the detail.
      You knew exactly what I needed to know!CHeers,
      Charles.
        Dinosaur | Sep 02, 2004 03:57am | #3
        You're more than welcome. And welcome to BT. The more the merrier....Dinosaur
  2. DANL | Sep 02, 2004 04:25am | #4
    An "air lock" entry would help--basically a small foyer with a door to the outside and not directly in line, a door to the inside. That may help some. If you have forced air heat you can put a cold air return in front of the door so the draft goes down into the furnace to be heated. Before "modern" HVAC, many houses had the cold air returns on the outside walls, especially under windows for this reason. But modern thought was to wash these areas with the hottest air. But this makes the greatest Delta T (difference in temperature) right in the worst place because at the greatest Delta T, you lose the most heat. This happens because heat wants to warm the coldest thing (not exactly scientific, but...) first. I think there was wisdom in having the heat from the furnace come up the inside walls, flow along the ceiling, giving heat to the room, and then drop down along with cold air coming from windows and such into the return air ducts. Sorry for the rave.
Forming Foundation Walls
In the first episode of FHB House Kansas, Travis and Joe of Catalyst Construction walk through details of their foundation walls.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 487: Cedar Closets, Conditioning a Woodshop, and Regional Construction Jargon
  • Podcast 487: Members-only Aftershow
  • Festool's Domino: Worth the Dough?
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
