http://www.makita.co.jp/product/category/setudan/ls0611/ls0611.html
(i cant read it but it looks pretty).
165mm @ 25.4 mm to the inch = 6.5" blade, about right comparing it to hand in picture
85,000 yen @ 115.95 to the dollar = $733 US
looks like it will be really light. (something that I find really enticing). tired of my 50lb dewalt.
Well it's slightly bigger cousin is 27.5lbs so it has to weigh less than that. Makita 7-1/2" Four Pole Slide Compound Miter Saw Model# LS0714
$425.90
Four steel poles with four linear ball bearings ensures stable, accurate and vibration-free cutting
Large dimensional lumber capacity: 2 x 12 at 90° and 2 x 8 at 45°
Double sliding mechanism for lighter, more compact design; weighs only 27.6 lbs.
Conveniently located carrying handle for jobsite portability
Powerful 10 AMP motor delivers 6,000 RPM
9 positive stops at 15°, 22.5°, 30°, 45° right and 0° for the most common miter cuts
Smooth easy slide system allows cross cuts up to 11-3/4" wide
Large aluminum turn base supports large stock for efficient cutting
Includes:
7-1/2" x 40T Carbide-Tipped Blade (A-90629)
Vertical Vise (122571-8)
Dust Bag (122523-9)
2 ea. Extension Wing (322312-4)
Triangular Rule (762001-3)
Socket Wrench #10 (782223-9)
Specifications:
Blade Diameter: 7-1/2"
Arbor: 5/8"
Max Cutting Capacities:
90°/90° - 2-1/16" x 11-3/4"
45°/45° - 1-9/16" x 8-3/8"
No Load Speed: 6,000 RPM
AMPS (120V): 10.0
Overall Dim. (LxWxH): 2-3/8" x 17" x 18"
Net Weight: 27.6 lbs.
