Has anybody ever heard of a plumbing system that empties out completely so pipes can’t burst in cold climates? I’m assuming greywater drainage only, which might remove the need for traps (composting toilet).
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
Traps are to prevent noxious odors/gases from coming back out of the system.
.1 - measure the board twice, 2 - cut it once, 3 - measure the space where it is supposed to go 4 - get a new board and go back to step 1
Edited 4/6/2006 11:12 am ET by Ricks503
I know. But w/ no septic and drywell for greywater, how noxious could odors be? Any such thing as waterless traps? Don't cut at all if you don't have to.
TRy a google for trap guard or trapguard.I think that is the product. Also good for floor drains where the water can evaporate.
I know what yur trying to say by your add on statement but you've got it all wrong.
Measure once Cut till your out of wood.
Even your gray water is going to create powerful odours.
Up here (Ontario, Canada), cottagers will slope their supply lines to drain completely, and pour RV anti-freeze into traps & toilets.
Regards,
Tim Ruttan
I disagree with those who say greywater will present problems. I know it's not code-compliant, but I have an outbuilding where I used a 2" backflow prevention valve instead of a trap. There is a shower, sink, and dishwasher. It's been in use for over 5 years. So far no problems, no odors.
Just be sure to slope the pipes well so they drain properly.
Scott.
Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
Edited 4/6/2006 12:14 pm ET by Scott
