noisey plumbing
rich539 | Posted in General Discussion on November 25, 2008 04:46am
has anyone had problems with toto tub shower valves making noise when any other faucet is turned on and off, even the toilet? the homeowner is blaiming the plumber for not clamping the water pipes. thanks rich d.
  1. Jed42 | Nov 25, 2008 05:12am | #1
    I'm assuming this is not your average everyday water hammer?
    No Coffee No Workee!
    1. rich539 | Nov 26, 2008 02:46am | #3
      no its not, just  a tap tap or thump thump rite in or near the valve . i have not taken the valve apart yet this toto valve has hot and cold stops rite at the valve also  a spool type balance deal in the valve  the homeower purchaced all the stuff but still blames us ( me and plumber) a royal pain ps they still hold all the cards (2500.00) thanks coop.
  2. jej | Nov 25, 2008 06:16am | #2
    what is your water pressure?
  3. Sungod | Nov 26, 2008 02:57am | #4
    If it is the tap tap tap noise that almost sounds like a loud drip, i know what is the problem is
    It is the hot water line expanding as it heats and cool. This is cause by clamping the copper directly to the wood. Those copper red rubber tipped clamps are the culprit.
    Some Plumbers will first wrap the pipe in something soft (like rubbatex) carpet padding then clamp it. A bored hole that is too small will prevent something soft to be stuffed on the tight side.
    Also, clamping copper directly to drywall studs will turn the whole ceiling or wall to a soundboard. A lot of Plumbers don't practice the art of quieting their pipes.
    1. Jed42 | Nov 26, 2008 03:06am | #5
      agreed...No Coffee No Workee!
    2. rich539 | Nov 27, 2008 04:02am | #6
      thanks for for the help but thats not it . i have one of those inspection snake cammeras (really kool looking down your mouth) i can see pipies and platic pipe clamps etc. it really seems to by in valve (the big ? is i didnt buy the stuff so how much time should i give for free to fix) i guess since they owe me i'll have to keep at it the plumber will not  stuck between that boulder and a hard spot thanks
Butt Joints in Decking
Avoid rot and split wood by positioning butt joints on a flat block with a dado for drainage.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
