b Help!! – Noisy Neighbor Upstairs
> We live on the 1st floor of a 30 year old condo bldg. The floors in between are made of wood. Our upstairs neighbor walks heavily (heels 1st). The floors squeak and his steps make a loud thud above our heads.
> We are tearing down the drywall ceiling to correct the squeak – add insulation – and add any other material to create a sound barrier.
>Any advice you have would be helpful.
>We’ve also heard about some special clips (screwed into the plywood and joists) that can be used to draw the plywood and 2×6 joists together. If you have info on this – please write!
b Help!! Noisy Neighbor Upstairs
> We are tearing down the drywall ceiling to correct the squeak add insulation and add any other material to create a sound barrier.
>Weve also heard about some special clips (screwed into the plywood and joists) that can be used to draw the plywood and 2x6 joists together. If you have info on this please write!
