Nolla Cabin, micro cabin, design and modifications
ketchgould | Posted in General Discussion on April 3, 2020 10:14am
We have 3 acres of land (Northern Wisconsin) that I want to build a quick, simple structure to use until we can build a permanent cabin in the future.  There is a cabin called Nolla: http://robinfalck.com/nolla
that seems very appealing.
I was hoping for a discussion on micro cabins and design ideas here in general with Nolla as a springboard for ideas.
The wood is Finnish Kerto LVL (Kerto LVL is produced from 3 mm thick, rotary-peeled softwood veneers that are glued together to form a continuous b​illet.)
What US wood product would you use to build something like this?
What would you use to protect the exterior from the elements?
Any modifications you would consider to the design?
What do you think is the span between the vertical a frames?
What is the simplest way to insulate the structure for winter use with temperatures below freezing? Sheet foam on the outside? zip sheets?
How would you deal with condensation?
And, what is the simplest most cost effective heat source without 110v power?
Thanks!
Christian
  1. florida | Apr 03, 2020 11:43am | #1
    I've built a lot of A-frames and would say that an A-frame would be the last thing I would build as a cabin, especially a small A-frame like this. They look cool but they live small, those sloping walls really limit your ability to use regular furniture and to walk around. In one the size you're looking at a second floor is almost impossible and would require a ladder and moving around on your knees. I would say there is little to no savings with one either.
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
