Bought a new Freud 10 inch blade for my Delta table saw. The red color blends in with the red table insert, tough to see at the some angles. Beware…..
Can you repaint the insert, or maybe strip the paint off of it? Or make one from plywood, or melamine?
*Local, I had the same problem with the freud blades on my Ryobi TS. I painted the table insert Bright Yellow. It works well for me. I also paint my plywood zero clearance inserts now. It sure helps you know where that blade is.
*Yea BD Tim has got an good idea, have you made an insert outta scrap oak or maple. youll get better cuts from a insert that has zero clearance
Bought a new Freud 10 inch blade for my Delta table saw. The red color blends in with the red table insert, tough to see at the some angles. Beware.....
