I am working on a bathroom which is 54″ wide the bathtub is the same , which I need to replace . Anyone one know where I can go for a new tub this size 54″x32″ Thanks Randy
There's a constant source of clean water for you to use, and all you have to do is collect it.
http://www.americanstandard-us.com/ProductNew.asp?prodID=236.
Many tub manufacturers have a short tub. Go to a plumbing supply house, I'm sure they'll give you a selection. Most likely an ordered product.
*Thanks Calvin thats what I'm looking for ! Randy
*i IF this is a replacement tub for a mobile home, be prepared in advance to do some replumbing - especially the drain hookups. James DuHamel
*No not in a mobile home , its in a house about 40 yrs old I don't know if its the original tub . Someone else mentioned mobile home when I asked for an under sized tub . Just glancing at it it looked like a standered drain set up , how did a mobile home differ from a framed house
*Randy,Most bathtubs in mobile homes are raised off the floor, and set on a platform (of sorts). The drain, and drain line are above the floor level, and require a lot of room. When installing a new, non-mobile home tub, it is designed to sit on the floor without the platform. When using one of these tubs, the drain and drain line must be installed at, or below floor level. Requires a lot of extra work. James DuHamel
*Thanks James I think I'm ok there the existing tub is on the floor now . Randy
