Trying to figure out the most cost effective way to keep 2 dogs away from wet oil base paint. The owners need to keep the dogs in that room. My concern is the baseboards. Let me know, also considering using an additive to increase the dry time.
Fine Homebuilding Recommended Products
Bluetooth Earmuffs
We appreciate the fit and comfort of these earmuffs, plus the Bluetooth capabilities allow you to field calls or listen to your favorite podcast while working.
Leather Tool Rig
This is tool rig is heavy duty, professional, and well-thought-out for tool storage — plus it can help reduce fatigue throughout the day.
Nitrile Work Gloves
Do yourself a favor and protect your hands while you work. These lightweight, breathable work gloves will keep your hands safe while cutting and fitting.
Plate Level
A plate level allows to you plumb walls accurately because it registers off the plates without touching potentially warped or twisted studs. This one can reach the plates on 12-ft. tall walls.
Large-Capacity Lightweight Miter Saw
This very capable miter saw weighs less than 30 lbs. and can cut a 2x12 @ 90 deg. and a 2x8 @ 45 deg. Precise cutting and smooth-adjusting controls make it a pleasure to use.
