I’ve got a circular 4’dia. double insulated aluminum framed window installed in my house, new construction although it’s at the finish drywall stage. The window frame is a typical narrow aluminum unit which leaves approx 4″ worth of space between the frame and the outer edge of the drywall to case and trim. I’ve seen a prefab unit on the net, consisting of the circular finish moulding and the inner casing or sill all together in one piece that should slide in the opening, align/fasten/caulk kind of thing. But for the life of me I can’t remember where I found it. I’ve checked marley, canamould, etc… Can anybody help? The drywall guys have made a friggin’ mess out of it as it stands and I really want to get a drop in unit to slide in and be done with it. Any help would be very much appreciated.
Bill Smith
These personalized workspaces were designed to fit the unique needs and projects of their makers.
I've got a circular 4'dia. double insulated aluminum framed window installed in my house, new construction although it's at the finish drywall stage. The window frame is a typical narrow aluminum unit which leaves approx 4" worth of space between the frame and the outer edge of the drywall to case and trim. I've seen a prefab unit on the net, consisting of the circular finish moulding and the inner casing or sill all together in one piece that should slide in the opening, align/fasten/caulk kind of thing. But for the life of me I can't remember where I found it. I've checked marley, canamould, etc... Can anybody help? The drywall guys have made a friggin' mess out of it as it stands and I really want to get a drop in unit to slide in and be done with it. Any help would be very much appreciated.
Bill Smith
