Does anybody out there order their mouldings online? or do you guys have local sources that help you out…..I need a wide cove moulding and this ones going to exceed the standard home depot stock. I’m open to all suggestions, thanks!
-Justin
-Justin
The recipe for linoleum hasn't changed much in nearly 170 years, yet it's still one of the greenest floors money can buy.
You might try Outwater. They have a good assortment of wood and other materials.
http://www.outwater.com/
thanks, but unfortunately they don't sell moulding - just other specialty stuff.
Try this URL for direct access to Outwater mouldings:
http://208.245.181.35/cgi-bin/worderc?confc=B2C
duh, I can't believe I missed that - too bad it doesn't come up with anything when you do a keyword search on their homepage! Thanks.
There's a place in Kent or near Cornwall, CT.
Andy E. probably knows the place. I think they'll make about anything you'd like.
EricI Love A Hand That Meets My Own,
Is there a small millwork shop or woodworker in your area that could make what you need ?
Mouldings.com
Whiteriver hardwoods in Fayetteville AR.
Now we're talking real money!
Fypon
Dykes
Windsor
all have coves 5-7" wide at least and can be bought through local outlets
A wide cove, make it on your table saw. It's not that hard and you'll save a bunch of money. Lonnie Bird's Shaping Wood gives a step by step and I think that FWW has several archived articles on it.
Jim
You suppose he can get the FHB archive search function to work properly?
Whenever you are asked if you can do a job, tell'em "Certainly, I can!" Then get busy and find out how to do it. T. Roosevelt
RE: Making cove moulding on the table saw.
Do you mean running the stock diagonally across the blade? I've had good success doing that ... rasing the blade in fairly small increments, and running the stock quite slowly. I get the correct profile by sighting at table-level, but I understand there are tables available that give saw tilt and stock feed-angle. Do the sources you cite include tables for 12-inch blades?
Thanks.
Allen
Running the stock through diagonally will give you a nice cove. You can offset the cove by the angle of your approach and/or by tilting the blade. Most of the sources are geared toward 10 inch blades since they are the standard, but with a little head scratching and samples run on scrap you can achieve some pretty good results. Just make sure the last two passes are done slowly and nibbling just a bit of material off the stock so that you don't spend the better part of forever sanding. And do yourself one additional favor, use push blocks just in case you set the blade too high.
Jim
Yeah, I considered running it through the table saw, but I need 100+ feet for the job, and I charge for materials so I'm figuring the time it would take me to cut all that stock wouldn't save me anything after I figure in labor.
www.homesteadhardwoods.com
They have excellent product, but the shipping is gonna hurt for only 100'.
