Open Starting Stairs Code Compliant?
I did this where no codes are enforced…so that makes it okay ; > )
What would your officials say? These folks needed the room to turn the corner with furniture, but say they like it open. Would a full length rail on the opposite wall allow it to pass?
Around my way you would get away with one open, not two.
SOmetimes it's all in how you present it to the inspector.
>> What would your officials say? << Doesn't matter. I live 1000 miles from you. But it wouldn't pass here. BTW - we use a watered down flavor of the IRC 2000 but we are getting ready to go to a modified IRC 2003 once they get done tweaking it. http://www.arcways.com/codes.htm
>> Would a full length rail on the opposite wall allow it to pass? << Here, we would still need a guardrail in addition to the handrail you propose.
Nope, not on a straight run. If there were two risers to a landing, then I could avoid a railing on the lower flight.
Andy
"Never try to teach a pig to sing. It wastes your time and annoys the pig." Robert A. Heinlein
"Get off your dead #### and on your dying feet." Mom
Ditto what everyone has said so far.
BILL
Wouldn't cut it in my area either, with or without a wall rail. I don't see either why you needed to put in the radiused starter step, I use them when I'm putting in a volute with balusters, just seems out of place, and a trip hazard.
Roger
I live just down the road from Matt, same code, different inspectors.This set of stairs passed last summer. As soon as I saw the rough stairs, I had a meeting called with inspections, and after a lot of hemming and hawing, this was approved.BTW, I think a wall rail would bring your set to code. I need a dump truck, baby, to unload my head
