FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
ordering concrete
John025 | Posted in General Discussion on November 1, 2006 10:55am
I’m getting ready to order my concrete for a retaining wall and I was wondering if there was a rule of thumb for how much to order. That is, it seems to make sense to have more than you need than not enough, so do you order more as a precaution, and if so how much? Also what do you do with the stuff you don’t use? I’d appreciate any insight on this….
John
  1. Litefoot | Nov 01, 2006 11:19pm | #1
    John
    I can order by the 1/4 yard from my supplier. So if I need 4.8 yards I will order 5. If I need 5 yards I will still order 5-1/4. I would rather be heavy than light on my pour. If you are using forms you should be able to calculate very closely what you need.
    My supplier takes back any concrete left in the truck back to the plant to be recycled. Concrete ingredients are measured by weight not volume at the plant before mixing. Sometimes you get exactly 5 yards sometimes you get a little more or less. The plants here are really good about getting you what you need. Hope this helps
    Mark
    1. John025 | Nov 01, 2006 11:51pm | #2
      Thanks! -- thats all I needed to know...
      1. brownbagg | Nov 02, 2006 01:38am | #3
        order 1/2 yard more than you need and do not look in the back of th etruck when you done. let the driver take it with him.
        1. Reg | Nov 02, 2006 02:55am | #4
          I always have some forms available so that I can use the extra concrete that I've paid for. 2'x2'x 3" concrete pads are useful, so I keep those forms available. Also find 10" diameter x 6" high circular pads handy for deck building, so I keep lots of drywall buckets available and fill them with about 6" of concrete. Though some of the castings get stored for a year or two, I still end up using them all.
          Order 1/2 yard more? Geez, I'd rather put the money in my pocket by measuring tighter.
          Randy
          Edited 11/1/2006 7:57 pm ET by Reg
          1. brownbagg | Nov 02, 2006 03:02am | #5
            because if you run short and have to order a 1/4 more, its a two yard minimum
      2. GOLDENBOY | Nov 02, 2006 03:48am | #7
        Here they take the excess back to the plant and pour lock blocks.
        Always better to have a bit more than you need!
        1. davidmeiland | Nov 02, 2006 04:09am | #8
          They do those blocks here too, but it's at my expense if I over-order. I measure carefully and add between 1/2 and 1 yard. I only go 1 yard over if the excavation is rough and there's going to be squeeze-out all over the place.
          Don't forget to feed the pump. The boom we usually use here eats half a yard.
  2. IdahoDon | Nov 02, 2006 03:05am | #6
    I've had good luck figuring the amount of concrete by rounding up to whole numbers for calculations, adding 10% and rounding up to the nearest 1/2 yard.   This is the formula we use for almost all jobs.
    Fastfoot, a fabric footer form has a great deal of variability as the fabric pooches out and the tops bow out so we use a 15% fudge factor, but it's rare to need that much reserve with normal forms.
    If using a pump truck I'll add 1/2 yard, although they will tell you it only takes 1/4 yard.  Too many times we'll have a series of clogs that results in mud everywhere as they take the hammer to the hose over and over.
    Two weeks ago an estimated 31 yard pour actually used 30.
    The week before I had my first short order on a very simple project.  Our footers were figured to 7-1/2 yards and the pour was slightly under 1 yard short.  A quick recheck and I said they sent 6-1/2 yards not 7-1/2, but it didn't get me far and we paid for another truck to bring one whole yard.  After rechecking the numbers and reconsidering the amount of form movement I'm confident it would be impossible to fit 8 yards in the forms which were extreamly straight and uniform for footer forms.  Other contractors have had similar complaints lately so it seems that it's good to double check what shows up and question loads that don't seem right.
  3. stikineriver | Nov 02, 2006 07:58am | #9
    Our batch plant works with volume and weight. If your forms are nice and flat, and the ground below the footing is smooth, you shoulld be able to get an exact amount, but if your numbers and the batch plants numbers don't jive, you lose and pay for the shortage. At $150.00 per CY here, i don't like to see the plany take any of it away, but they always do. It's like the baseball manager complaning about a bad call, the guy in the stiped shirt wins, no matter who was right!
Lessons in How to Decarbonize Existing Homes
Sustainability consultant and educator Marc Rosenbaum, P.E., shares an overview of the topics he covers in the new e-learning course.
  • Balancing Window Selections for Performance and Budget
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
BOOKS, DVDs, & MERCH
Shop the Store
  • 2024 Tool Guide
    Buy Now
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
