OSB: Nails or Staples for Roof Decking?
I was looking over a “Tuff Shed” two-story building with a Gambrel roof. I noticed that the roof decking was OSB and in several places I saw it was attached with 1/2″X 2″ staples that missed the rafters….
It made me wonder what is really best to attach roof decking?
Thanks,
Bill
Screws.
Man, I just couldn't resist.
Also a CRX fanatic!
Okay I'll bite.
IMO staples are better, only because at the pressure I use nails penetrate too deeply.
In any area except where significant sheer forces are involved, i'd go with staples, but at 3" OC minimum.
Just try it. staple the sh*t some ply and nail equaly then try to pull apart. use your own judgement after that.
I've nailed plywood to a fake frame and stapled also then took a sledge to the frame and the nailes ply showed more movement. I lost a bet on that count...........
HMMMMM............. makes me wonder what the codewriters have tested ... on an 8' sheet in one stud where the ply breaks 4" oc = 64 nails with a .12 diameter shank in a 8' x 1.5" area ............. splitsville like me an my X
You are right. Best is to hit the rafter
