I am building a home in Omaha, Nebraska – cold winters and hot, usually dry summers. I have a choice between putting up half inch oxboard sheathing (OSB) covered with Tyvek and then lap siding, or putting up 3/4″ Dow Styrofoam insulation in place of the sheathing and Tyvek. The Tyvek and sheathing option costs a little more, seems sturdier, and appears to be what the higher end homes get. My builder thinks the Styrofoam is the better way to go – he indicated it will have much better insulation qualities. Which has the better “R” value? Which option will provide best overall performance considering the lap siding (stability needed) vs. R-value?
Keeping HVAC systems within the conditioned enclosure can be tough without a basement; one option is to use plenum trusses for the roof, which offer a space for equipment and ductwork.
I am building a home in Omaha, Nebraska - cold winters and hot, usually dry summers. I have a choice between putting up half inch oxboard sheathing (OSB) covered with Tyvek and then lap siding, or putting up 3/4" Dow Styrofoam insulation in place of the sheathing and Tyvek. The Tyvek and sheathing option costs a little more, seems sturdier, and appears to be what the higher end homes get. My builder thinks the Styrofoam is the better way to go - he indicated it will have much better insulation qualities. Which has the better "R" value? Which option will provide best overall performance considering the lap siding (stability needed) vs. R-value?
