Im having my backyard concrete deck replaced (So. Cal.)with new concrete and currnetly have an existing gas fire pit. My contractor is going to charge $1400 to build a replacement 30″x18″x18″ gas fire pit, this seems expensive for a small pit (with existing gas line), I want a 48x18x18. It seems possible to have him just “stub out” a gas line thru the concrete deck and build it myself (at a later date) on top of the new concrete deck, with concrete block and veneer it with rock. Any suggestions if I go that route? (length of threaded pipe sticking out of deck?, 3/4″ size?, drain/weep hole issues?, etc…this 1400 will break the budget Thanx in advance
Michael Hindle explores the efficacy of deep energy retrofits and discusses essential considerations for effective climate mitigation.
Perhaps you could start by learning how you run gas line through concrete?
Some of that $1400 is for know what to do, some for materials, some knowing how to do it, and some for being able to do it well.
I don'r know if that figure is high or not, though.
