Question:If code requires 8d nails every 24inches oc, can I nail every 16 or 20? So, basically can i just get in the ballpark and shoot away??? So really the question is, is there anything wrong with overnailing slightly.
What are your guys thoughts?????
Oh yeah I overnail all the time.
Sometimes we get specs. for 4" OC on the edge and 8" in the field. So I shoot'em off at 3 and 6.
I'm not messing around w/ trying to get them exact.
I do the same thing with drywall. I just eyeball a foot an screw it to it.
I should add that when we do have a nailing spec like that we have to use a 3x6 at every panel edge where the two sheets butt and any blocking needed on panel edges.
So I think as long as you're not getting too carried away it's just increasing the shear strength.
Dave
Edited 7/18/2008 2:55 am by DaveMason2
Building code is just the minimum that you can get by with. When you're talking structure and load, a few extra nails won't hurt a bit.
Thanks for the advice. I noticed my gun was 22 inches long, so if I shot a nail every guns length I should be covered. My rookie self was measuring and figured there really must be a better way. I was just worried my inspector would look down upon 'in the ballpark' nailing.
Thanks again
I usually do it by nail count. If nails are supposed to be 12" apart, then a four foot sheet gets 5 nails across.
