any reason I need to back prime window jams ( ie moisture) or does it just get put up and primed and painted in place?
ounce of prevention and all that
and use oil or shellac base primer- water base makes the surface fuzzy
you can top coat with anything then
I do and I would just in case, easier now than replacing swollen jams latter.
Edited 12/29/2005 4:42 pm ET by byoung0454
Alrightythen-
I've never painted them, and don't think it's typically done. I can't say I've ever noticed it done. Sounds like wasted time.
That said, check with the manufacturer. Curious if they say different.
Don K.
EJG Homes Renovations - New Construction - Rentals
I'm making custom window jams from sheet stock. so I guess that makes me the manufacturer...sort of.
Shellac.
Phill Giles
The Unionville Woodwright
Unionville, Ontario
