Painting trim
| Posted in General Discussion on January 13, 2005 05:38am
I am painting my brothers master bedroom.  He has trim that is stained, and they want to save it and repaint it in some semi-gloss color.  Will primer alone do the job of locking in the stain so that I can paint right over it, or should I really try and talk him into getting new trim????
Nix
    coonass | Jan 13, 2005 06:08am | #1
    Nix,
    Prime with Kilz oil. It seems to stain block anything. Stinks!
    KK
  2. jimkidd2 | Jan 13, 2005 06:22am | #2
    Kilz works. BIN works faster. Either way, make sure that you get at least two good coats on the wood, give it a light sanding with 200 grit paper then paint. Remember, when it comes to painting it's all in the prep.
    Jim
    "I want a good clean fight. No head butts, no rabbit punches, and no hitting below the belt. Break when I say break, and protect yourself at all times."
    IMERC | Jan 13, 2005 06:33am | #3
    sanding sealer ir Kilz 1st..
    WOW!!!   What a Ride!
    1. johnharkins | Jan 13, 2005 06:56am | #4
      those kilz & bins good - like previously mentioned oil or ones you clean w/ ammonia best
      not privy to the stain makeup but another worthy step or two would be to hit the surface w/ some MEK or like then light sand then tack w/ MEK or thinner and then prime
      you've provided better tooth for that primer and yrs down the road when someone nixes that trim the primer and maybe more will stay rather than the primer and all coats above chipping off
    IMERC | Jan 13, 2005 07:02am | #5
    how old is the stain and cover coats..
    WOW!!!   What a Ride!
    1. nix446 | Jan 13, 2005 04:25pm | #6
      it is very old, 10 years maybe......
      Nix
        IMERC | Jan 13, 2005 09:23pm | #8
        sanding sealer 1st...
        WOW!!!   What a Ride!
  5. stanleyj2 | Jan 13, 2005 06:30pm | #7
    Nix:
    I think that you will get better and more durable results by priming with Benjamin Moore Fresh Start oil based primer and following with an oil or latex enamel topcoat.
    Stan
    1. nix446 | Jan 15, 2005 04:53pm | #9
      thank you all very much
      Nix
  6. mike4244 | Jan 15, 2005 08:51pm | #10
    Shellac, or any shellac based primer like Kilz. Kilz makes a water based primer also, do not use this.The other Kilz is shellac based.
    mike
    1. nix446 | Jan 16, 2005 05:05am | #11
      thanks Mike, that sounds like what I am going to do after some light sanding.
      Nix
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
