I used PALRAM Palight trimboard for first time building out pvc windows. What are experiences of anyone else that has used it ?
Greetings artworks,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
94969.19 In the beginning there was Breaktime...
94969.1 Photo Gallery Table of Contents
Thanks. Just wondering about others experience.
how was your experience with it?
http://www.palramamericas.com/docs/upload/F1303_Trimboard_Tech_Hndbk_11-17-06.pdf
PALIGHT¯ Trimboard T e c h n i c a l h a n d b o o k Toll free: 800-999-9459 | http://www.palramamericas.com PRODUCT DEFINITION Palight Trimboard is a flat, rigid, extruded solid foamed PVC sheets for Indoor & Outdoor applications. FEATURES AND BENEFITS • Excellent UV resistance • Durable, never rots • Easy to paint & maintain • Excellent mechanical properties • Good insulation, lower heat transmission • Easily worked with conventional tools and paints • Can be easily bonded, formed, nailed and bolted • High chemicals and humidity resistance • Non-toxic • Not degraded by insect damage
artworks,
curious on your thoughts of it versus azek
First time I have used a pvc product, not alot used around here & not usually stocked yet, lumber dealer mentioned it when I needed to buildout inside of windows 4 3/8" . I installed Jelwed with a 3/4 return , alot cheaper than custom 6 3/4 jamb. ( $1.95 / ft ) The only thing was "saw dust" clings to everything. I think I will use it for brickmold on a couple of PVC window box units I have around for my sons porch were building.
I use it for exterior window trims, corner boards and other trim on fiber cement siding jobs, even occasionally for window jamb interior extensions (smooth side showing). I like it quite well. On window trims I join pieces with a 3/8 x 1/8" slot cutter and splines that I slice off a piece of scrap w/ clear pvc cement. Works well. I usually nail it in place w/ galv 16 ga. gun nails and fill the holes but I have screwed it on with ss trimheads a couple of times.
Don't leave the protective film on too long after it's installed - it gets brittle and hard to peel off when it's been in the sun for a while.
I pay a bit less for it than for Azek in 3/4 thicknesses. Full inch thick (sold as 5/4) is about the same as Azek.
j
