Why do we burn through palm nailers? Seems I can only get about 6 months out of them. I’ve owned two of the better Sencos (around $90 I think) and since those two have been buying cheapo Cambell Hausfield ones with the same results.
After a few months of use (moderate to heavy I guess) they start leaking air out the back. Take ’em apart, clean the seals and everything else I can get at, put ’em back together and get a couple weeks out of ’em. Then one week. Then a day or two etc. etc….
I’ve replaced the seals/rings in the Sencos, but they still don’t last even the 6 months that the originals did.
What am I doing wrong? I only use oil recommended for air tools (Bostich brand) and can’t imagine what else I should be doing for them.
Anyone else have this problem? Any suggestions?
yeah, I got a tiawanese POS..it did that, I did find it was a REAL THIN seal inside..I don't have the exploview handy..but it would not seal for long..bad news is I forget what I did to fix it, but it works ok now..I don't use it enough to really say it's fixed, just that this time it's lasting longer.
Are those Senco's the good but discontinued A-9, or the cheap imported A-20?
-- J.S.
A-9's from Tool Crib.
One thing I have noticed about palm nailers is the bolts back off regularly and then the seals blow so I tighten twice a day.
ANDYSZ2
I MAY DISAGREE WITH WHAT YOUR SAYING BUT I WILL DEFEND TO THE DEATH YOUR RIGHT TO SAY IT.
Remodeler/Punchout
gee this is good news, just bought and paid for 30 bucks worth of seals for the A9 Senco, and you're saying they don't last after that?
I have an older Senco, probably the A-9 model, it leaks air out the back, but still works. It seems to be hard to get the gasket set. At least for the tool places I go. I just tighten the bolts down and keep going. I have found that the Senco takes about twice the oil that a normal framing nailer takes. I oil it twice a day instead of just once is what I'm saying. You might try going to an auto parts place and buying some gasket material and making your own. Maybe worth a try.
Sorry I don't have the model number here right now, but I recently bought a Makita nailer that works like a palm nailer but has a pistol grip instead. You pull the trigger and nothing happens until you press against the nail, then it starts the bam, bam, bam like a palm nailer. It has a narrow "buisness end so it can get right into corners if needed. All in all, it just seems more substantial and hopefully will give longer service.
Having said that, I have have had good service from the original "Palm" brand nailers we bought a couple years ago. We bought the model with the
lo-o-ong tip, which really worked well with skewed hangers.
