patching leak in situ?
tufenhundel | Posted in General Discussion on December 22, 2006 06:07am
I installed a second sump pump and had to cut into the existing drain. Now there is a small drip in my PVC connection. I’d rather not take it apart to repair because the sump is constantly filling now.
Is there a way to patch this? The drip runs back into the sump, so I can limp along for now. Just like to hear some ideas. Thanks.
  1. JFord | Dec 22, 2006 06:32am | #1
    Try getting it as dry as possible and running some pvc cement over it.
  2. DanH | Dec 22, 2006 07:45am | #2
    This came up a few days back. It was stated that if you heat the joint with a torch or hot air gun before applying the solvent, it gets sucked into the joint just like solder in a sweat joint.
    People never lie so much as before an election, during a war, or after a hunt. --Otto von Bismarck
    MarkH | Dec 22, 2006 07:47am | #3
    duct tape
      IMERC | Dec 22, 2006 07:50am | #4
      after the heat gun trick...
  4. splintergroupie | Dec 22, 2006 11:09am | #5
    I tried three times to get a repair coupling on a 3" PVC drain to take, but could never get enough cement in or work fast enough to fix it perfectly. Instead of cutting it out and buying more fittings, i finally slathered Plumber's Goop around the leaky bit, on the outside. I doubt it would work if you couldn't get it dry for a half-hour or so, though. You can use a hair dryer to speed up the drying.
    This isn't a top-flight fix, but it worked for ten years before i sold the house.
    Fonzie | Dec 22, 2006 09:36pm | #6
    tufenhundel,
    A long time ago in a desparate situation I used thin strips of cloth impregnated with clear silicone rubber and stopped a freeze leak in an odd, impractical - to - replace fitting while it was still dripping.
    I just went around, adding silicone rubber like taping drywall. It held for years.
    That being said, I have been more impressed with Gorilla Glue than any I can remember. I have yet to have a failure with it. It reacts somehow with water. There might be a possibility you could put it in the right place and "drive it in" by sealing over with tape.
  6. pagoda | Dec 22, 2006 09:44pm | #7
    in Fla they have a solvent for  pvc that works even if there is water in the joint area
    the stuff is purple and comes in a can that looks like the regular can only it is purple
    all the pool repair guys and the sprinkler guys use it  and i saw it in home depot there whe i used to live there and used it myself
