Hi All,
I need to frame standard shed type roof for an open patio, 10′ Span, 30′ Wide. 1/12 roof pitch &rafter 24″ O.C. Will attach to an existing building via ledger board. 3 – 4×6 posts and Glulam at the other 10′ end. Do I need to use a joist hangers (not the correct angle) or rafter hangers where the rafter ties onto the ledger board or is toe-nailing the rafter into the ledger enough?
I will remove the stucco and get down to the wall sheathing for the ledger and secure with 3-1/2″ x 3/8 lags 16″ O.C. into the wall studs.
Help is appreciated!
Chris
A 1/12 pitch is less than a 5 degree cut..... I think standard hangers will be fine.
