Pergo Flooring
Smitty21 | Posted in General Discussion on March 10, 2006 01:14am
I had Pergo flooring installed on my main floor with the exception of two rooms. The two rooms that I’m going to finish have carpeting and I’m concerned that there will be a significant difference between the existing Pergo flooring and the sub-floor below the carpet.
Any advice  on how to compensate for the height difference?
Thank you.
  1. philarenewal | Mar 10, 2006 01:56am | #1
    If you've already gone with the Pergo, you might as well go with the Pergo transitions as well.
    Here's a link to an example.
    http://www.pergo.com/shop/ProductInfo.aspx?productid=A123
    You can also get transitions made of real wood at most decent lumber yards.
    Out of curiosity, what sold you on the Pergo?
    "A job well done is its own reward.  Now would you prefer to make the final payment by cash, check or Master Card?"
    1. Smitty21 | Mar 10, 2006 05:33am | #2
      philarenewal
      Thank you for your response. I choose pergo because it was less expensive than real hardwood, and a friends personal experience.
      Thanks.
Tall Deck on a Sloped Lot
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
  • Sharp-Blade Solution
