In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Pet smells in crawl space and basement
COremodeler | Posted in General Discussion on June 4, 2005 09:20am
I had a tenant who apparently locked their pet in my rental property’s basement, nice huh. I’ve completely demo’d everything down to a dirt floor and concrete walls and the smell is as intense as ever. Anyone have suggestions on removing the smell? I’m tempted to hose it down and see if the ground can break down the animal waste. The house is completely gutted so the moisture shouldn’t be a problem. I’m going to remodel and sell the place but not w/ this smell, any thoughts.
  1. rob26 | Jun 04, 2005 10:00pm | #1
    I'll start off by telling you I don't have any idea how to handle the problem on the dirt floor. On concrete, however, I was able to remove some pretty intense dog smell by scrubbing with Lysol, rinse with clean water, repeat. Then, use a garden-type sprayer to mist the area with a 100-200 ppm bleach solution (about 1 - 2 oz. per gallon of cool water) and let it air dry. I did this twice, included the bare concrete foundation walls, and the basement smells as clean as a swimming pool. The chlorine smell dissipates, but the dog odor has not returned in four years now. Actually, now that I think of it, try your local pet store for their "pet odor neutralizer" product, and try misting that solution on the dirt floor. Won't hurt, but might work. Good luck - I know what you're dealing with, and it isn't pleasant.
  2. DanT | Jun 04, 2005 10:11pm | #2
    I mentioned this before and a number of others said you needed a chemical suit to do it but I have used lime a number of times with great success.  Just go to the local masonary supply place and buy lime for masonary.  Lay a couple of inch layer on the dirt.  Smell will be gone in a few days.
    As far as the concrete goes mix a solution of 50/50 white vinegar and water and slosh this on the floor and leave it.  It takes a week or so for the vinegar smell to go away although you can work in the place after a day or so but feel like a pickel.  DanT
  3. saulgood | Jun 04, 2005 10:14pm | #3
    That's rough, CO.
    I've got a similar situation in a room in my house, only it's a cat/wood floor thing. Internet research was not very encouraging; with a wood floor, if the stain is deep, REMOVAL is the only solution. Do you know what animal it was? If it was a cat, your problem is more difficult. I wouldn't use the hose as a solution, it might just drive the smell deeper. The best way to start is to find out exactly what you're dealing with - it may smell like it's coming from all over, but pets often target one specific spot. Buy a common "black light" bulb (I'm not exactly sure where to get these, but they're easy to find) and turn it on in the otherwise darkened area in question. The urine will show up as white spots, or yellow if it's very old, and you'll know the extent of the problem. If it's in the dirt, I'd say dig it up completely. If it's on the wall, You might be able to wash it off, but then you may need to dig it up from the ground anyway.
Using Liquid Flash at a Wall-to-Foundation Connection
Brian Pontolilo demonstrates how to air-seal where the concrete foundation, mudsill, and ZIP System sheathing all meet.
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
