PEX For Heating Questions
| Posted in General Discussion on January 4, 2000 11:44am
I want to use PEX to run some lines thru a cramped crawlspace for hotwater baseboard heat (in the rooms above the crawlspace). So I’ll need to have a connection/adapter from the PEX to 3/4″ copper pipe.
Questions:
1)Is there a brand of PEX that doesn’t require the expensive installation tools? I’ll only be doing this once.
2)In this situation is it best to have the PEX-to-Copper connection above the floor or below?
3)Is PEX only sold in rolls of 300 feet? I doubt I need half that much.
4)Is there a difference in type of PEX for radiant-heat applications versus PEX for transport-only of hot water? (ie I don’t want to heat the surounding area of the PEX, just to transport 180 degree hotwater. So maybe I should put pipe insulation around the PEX?)
Any other thoughts or suggestions about this would be greatly appreciated.
Phil
  1. PatchoguePhil | Jan 04, 2000 11:44pm | #1
    I want to use PEX to run some lines thru a cramped crawlspace for hotwater baseboard heat (in the rooms above the crawlspace). So I'll need to have a connection/adapter from the PEX to 3/4" copper pipe.
    Questions:
    1)Is there a brand of PEX that doesn't require the expensive installation tools? I'll only be doing this once.
    4)Is there a difference in type of PEX for radiant-heat applications versus PEX for transport-only of hot water? (ie I don't want to heat the surounding area of the PEX, just to transport 180 degree hotwater. So maybe I should put pipe insulation around the PEX?)
    Phil
The Trump Administration Wants to Eliminate the Energy Star Program
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
