I’m tired of pulling out 75′ of hose every time i want to wash my truck, so i’m thinking of running some pex out to the side of my garage.
my questions are what size for about a 60′ run and having never used pex before what tools do i need? i’m thinking about using shark bite fittings,am i correct? thanks fred.
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
bump
Will the line be buried at any point?
Is there danger of freezing?
1/2" pex will deliver about 7gal/min at 50 PSI over that distance, so that's more than enough to wash your truck.
Any approved, listed fittings will work. Sharkbites cost a little more, but you shouldn't need many fittings. You should be able to buy a 100' roll of PEX and eliminate any need for couplings.
Pex shouldn't be exposed to sunlight as it's not UV stable, so be sure to figure for a copper cut over if you need run the supply on the exterior. You can get an inexpensive well made crimper from pexcrimper.com if you want to go that route.
Z
